Sponsored by: CARiD
speedometer broken
Old Jul 4, 2011 | 02:09 AM
Rednaxela's Avatar
Default speedometer broken
hello all:
my 2002 camaro's speedometer is broken. it only moves to 1/3 of my actual speed (if im going 60 it will show 20)
i have 4.10 gears - if that helps diagnose the problem...
my friend says it is likely a speed sensor?
can anyone help me with this issue?
Old Jul 4, 2011 | 05:10 AM
cemlsx's Avatar
yes you need to recalibrate your PCM if you've changed your gears .. your speedo is off.
get hp tuners or a mail order tune to get it fixed.
Old Jul 4, 2011 | 06:37 PM
Rednaxela's Avatar
i forgot to add that my speedometer worked totally fine up until a couple months ago - that means my speedo must have been calibrated already huh?
Old Jul 7, 2011 | 10:49 PM
FiredUpZ28's Avatar
Check for BCM codes.
