Sponsored by: CARiD
ac help
Old Jul 6, 2011 | 09:08 AM
drago1217's Avatar
Default ac help
I thought my compressor was bad but it turns out I have a big leak on my line running from the condensor to compressor. It was laying on my sway bar and rubbed a hole. But that's not tthe question. To find the leak I charged all. The way up. And I had to pull the compressorr relay and jump it to kick on the compressor. I let it run fo like 20 min blowing ice cold. Then pulled the battery to clear the code. Put relay back in and nothing. Tried a new relay and nothing. I see the high pressure sensor on top but where is the low pressure sensor. Is there one. Once I put a new hose on and charge again will the comressor kick on? What do I have to do to get the comp to kick back on?
Old Jul 7, 2011 | 11:13 AM
drago1217's Avatar
Anyone? I am picking up a new hose today and would like to fix this tonight
