Window rattle
I looked on the "Shoebox" tech page, and although there's a slick video showing how the window assembly operates, it appears that this roller is "hidden" by other parts of the window assembly. Has anybody ever been able to replace this roller? Any advice?
TIA!
The common issue is the post holdng the roller breaking entirely. Very low possibility that your problem is a worn roller...
Actually, I had the door apart earlier this year, looking for the source of the noise. The "stud", or post is still in one piece, but the roller wobbles all over the place. After I got that far, it took a while to track down a pair of the rollers. Now, I have to track down some time to get the door apart again.....
Once you have the before/after, please post a pic. As the cars age, worn rollers will become more common.
I took the interior panel off last fall, to check out the issue, and that's when I found the problem. It took a while to track down what I thought would be the correct part, as you mentioned, a lot of these parts are being discontinued. Also, I had put the interior panel back on, so I could drive the car, so I was looking at pictures of parts, trying to guess which one was what I wanted.
By the time I finally had gotten a pair of the rollers, winter had set in which means two things for me...1) it's gets pretty cold in the garage, colder than I want to be, while working on the car; 2) I have two cars "shoehorned" into a car-and-a-half wide garage, so getting a door wide open to remove the interior panel again, isn't going to happen.
I was going to tackle it yesterday, but it was around 90* out, and I said "the hell with it", and stayed inside, in the AC. It's amazing how you change over the years...when I was in my 20s and 30s, I didn't care about the temps, icy cold or hellishly hot, I worked on the car. Now that I'm pushing 60, I just don't quite have as much drive as I used to have. I'll work like a dog, once I get started, but sometimes I just don't feel the urgency.
Nonetheless, the rollers I was able to get my hands on, were Dorman p/n 74407. Hopefully, the shank portion of these things is the correct length.
