LS1 jerks right before complete stop. Help
Go on the automatic forum and do a search for "clunk" and you'll find some old threads about this. This may be what you're experiencing.
I had my transmission rebuilt by Aamco @150K miles and this condition never changed. There is also another oddity I have noticed, which may be a fact of life, or a sign of a trouble. It's not easy to induce the problem, but if a large, harsh bump is encountered at moderate-to-high speeds around a tight corner (like say, a drainage gutter across the corner crosswalk), the transmission will be thrown for a loop from the harsh impact. It will prematurely upshift or downshift at that moment (I can't recall exactly), but only if it was about to do so already. Because it's premature, this will cause drag and it's not very enjoyable when it happens. I was wondering recently if this might be caused by a bad tranny mount, or even a bad engine mount? If so, it occurred to me that it could be causing the clunky shifts when coming to a stop. Is this easy to check for?
I also took apart the IAC (idle air control) valve/motor. I tried to clean it, but I think it was just too jammed up with oil and deposits to ever work again. It looks fine and the plunger moves now (it was completely jammed before), but I think it may have stripped out internally pulling it apart or it just may have been stuck from the start. The plunger had about a half inch of carbon deposits from the bad PCV valve I just replaced, so the whole thing was clearly not working for some time now. I have to pick up a new one soon (I unplugged it for now as it just idles increasingly high when plugged in, but at 1200 RPM in park or neutral and 950 RPM in drive or reverse when it's unplugged with the plunger left extended) and I'll report back if that has fixed the high idle.
This is important, as I suspect that the engine fighting the brakes (the high idle is like having your foot on the gas and the brakes at the same time) may be cause for the abrupt transition to a stop. It also meant having to hold my foot down on the brakes harder than most other cars to hold still at a stop. Granted, this was with the idle at 800 or 850 RPM, which I just took to be normal. But foot off the brakes, the car would speed up as would RPMs, which I expect to go away with the new IAC. The new transmission mount will surely cure the shifting in bumpy conditions, but I'll have to report back if the jerkiness before a complete stop (like the OP) goes away.
