Sponsored by: CARiD
Water pump help
Old Jul 26, 2011 | 06:08 PM
midwest_98's Avatar
Default Water pump help
Water pump is bad on my 98 Z. Friend of mine is Store Mgr of local repair shop and quoted me at 650.00......that just seems really high. Advanced Auto Parts says its like 150.00 for replacement. Doesnt seem like would be to difficult to change. Anyone have any references to a tutorial on changing out. Any and all help is appreciated.
Old Jul 26, 2011 | 06:48 PM
ROCNDAV's Avatar
Here is an article on how to install an electric water pump.
You only need to look at the removal section and reverse it for install.
http://ls1howto.com/index.php?article=26
Old Jul 26, 2011 | 07:02 PM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
I'm going to save you money... Ready?
Go on Advanced's website, check out online and select "store pickup". Enter coupon code VISA and save yourself 50 bucks, and STILL have a lifetime warranty.
And yes, it's very easy to change. It's only 6 bolts...
Old Jul 26, 2011 | 08:13 PM
LS6427's Avatar
Sorry, your friend is a dirtbag.........
You can buy these things for under $100.00.00
www.rockauto.com has factory AC Delco water pumps for $183.00 and a couple others that are just fine for under $100.00
Old Jul 26, 2011 | 08:16 PM
LS6427's Avatar
There ya go.....winner right there and that warranty....
Old Jul 26, 2011 | 09:03 PM
bad_408_vert's Avatar
WOW! Some Friend you have!!!
You can do it yourself for about $100.
Pump comes with a gasket and you need a bottle of coolant.
I took off the lid to make things easier, Took off the belt and pulley to access the pump.
Drained old coolant from the radiator's petcock.
Scrub off the paper gasket off the motor, apply new gasket with some black rtv,
install new pump and rest is reverse process.
Fill radiator with fresh coolant (hope you plugged the petcock back on bottom of radiator before this step. )
Make sure there are no bubbles.
Let the car sit for 4 to 5 hours for proper sealing.
Old Jul 27, 2011 | 08:26 PM
midwest_98's Avatar
Thanks guys!
Old Jul 28, 2011 | 08:03 AM
runtwrestlin's Avatar
Wow...wish I had known that. I bought my water pump from Advance a few months ago
Does that work for other items? Heh heh heh
Old Jul 28, 2011 | 04:05 PM
sjsingle1's Avatar
i got new GM gaskets for the pump...the 1s that came with my new pump did not look to stout......doing the job twice is never cheap
Old Jul 28, 2011 | 04:11 PM
myk's Avatar
myk
Maybe your friend thought you had an LT1. Just playing devil's advocate...
Old Jul 28, 2011 | 06:58 PM
The only thing to be careful about lt1s is opti getting wet. For a pro it doesn't matter as much. ..good to see you back here myk.
Old Jul 29, 2011 | 02:35 AM
myk's Avatar
myk
How's life in the big city man?
