Cruise control not working HELP
1) I popped my hood, check the ac/cruise 15a fuse, not blown
2) proceeded to under the steering colum/dash, its held inplace by 4 screws, i unscrewed them som bitches, unhooked the hatch button/switch, and found the brake light switch
It has 2 set of plugs attached to it, and they are a pain in the *** to come off, i have weak fingers so i had to use a set of pliers to unhook them.
Then the brake switch unscrews
I put in a brand new one, made sure my brake lights were functioning properly
and then the bad part,
CRUISE STILL NOT WORKING
idk whatelse to check now.. anyone care to chime in?
fuse - check
original brake light switch secure - check
new brake light switch replaced - check
3rd brake light works, it just wont set a speed
any ideas?? http://www.rickscamaros.com/camaro-c...1994-1998.html
94-98 cruise control release switch?.. anyone know where this **** is at?
When I checked, sure enough the switch was not contacting the clutch at all, so I'm guessing the PCM thought the clutch was pressed in the whole time and not letting the cruise work. I had to screw in the switch about 3 or 4 turns and now all is good.
The third tail light works, the clutch switch works, so I am at a loss. This happened on my 97 T/A as well but I never looked into it (as I never used the cruise control then)
I am looking forward to someone finding the answer other than the clutch switch. I will keep looking myself.
I rarely use Cruise so I can only assume it went out when I put in the LS7 clutch or replaced the master cylinder.
