New Belt, New tensioner, or manual tensioner
Old 08-05-2011, 03:07 PM
jam01's Avatar
i still have my original tensioner, i figured it was still good and the only reason i changed it was it was making noise. i greased it like it showed in a write up here. the part came from canada, so blame the canadians. lol
Old 08-05-2011, 08:55 PM
Save the manuals!
wssix99's Avatar
You can't blame Canada!
The whole car was made there!
Old 08-09-2011, 09:37 PM
25thhawk's Avatar
Just an update. I used the high shouldered gates pulley and is working fine so far. Many wot runs and shifts. No problem. Only thing I had to do was put a longer belt on. This was partly due to the larger pulley and also due to switching to a truck alternator at the same time. I had to switch from a 76inch belt to a 78inch belt.
Old 08-09-2011, 09:57 PM
LS6427's Avatar
Make sure you inspect that belt frequently though....the inside of that belt gets eaten up because every time you wack the throttle its gonna slam against that "wall" that keeps it on the pulley, and get worn. People with the Larry Pulleys always complained of the inside of the belts getting frayed.
Let us know in a couple months how your belt looks.
Old 08-09-2011, 10:16 PM
25thhawk's Avatar
Yes absolutely. I will update in a couple months.
Quick Reply: New Belt, New tensioner, or manual tensioner
