Sponsored by: CARiD
engine temp question
Old Aug 13, 2011 | 05:03 PM
88monte's Avatar
liqour enthusiest
Default engine temp question
my gauge cluster reads the cars running about 240, in autotap it shows the engine coolant temp sensor is reading 146. its got a 160 thermostat in it and i wired the fans manually. i replaced the temp sensor in the head, thermostat, water pump and flushed the radiator. could i just have a shitty gauge?
Old Aug 13, 2011 | 10:01 PM
LS6427's Avatar
These guages are terrible, that one is way far off though. OR.......Failing coolant temp sensor...change it.
Old Aug 14, 2011 | 01:16 AM
wrencher's Avatar
wrencher
99 & up the PCM tells the cluster the temp to display.
I'm Betting your cluster/gauge is to blame.
Old Aug 16, 2011 | 07:19 PM
wssix99's Avatar
Save the manuals!
Something else isn't right!
If you have a 160 thermostat, the true engine temp should be AT LEAST that temperature.
