Sponsored by: CARiD
urgent electrical problem!
Old Aug 19, 2011 | 11:54 AM
epg_xtony's Avatar
Default urgent electrical problem!
good morning, I have a 99 trans am that i bought on monday and whenever i turn the engine off and remove the keys the power stays on. I cant figure it out, what could be the problem?
Old Aug 19, 2011 | 09:36 PM
epg_xtony's Avatar
Ok so update, I have found that the inside fuse panel had a copper wire connecting the defroster to the window fuse (both breakers) and that's the only way for radio and windows to work. Neither work without that bridge.
Old Aug 20, 2011 | 10:21 AM
Danny Thomas's Avatar
Exactly what stays on..windows and radio?
Old Aug 23, 2011 | 05:04 PM
epg_xtony's Avatar
yeah just those two. well the antennae goes up and down with the radio too.
Old Aug 23, 2011 | 05:07 PM
Paul Bell's Avatar
That's MISTER MODERATOR
TRY THIS:
Staying in the car, shut it off and remove the key. Observe the radio and windows continue functioning. Open the door. Notice the radio and windows stop working the moment you opened the door.
This is the "retained accessory power" feature in our cars.
This is the normal operation of the feature.
Old Aug 23, 2011 | 05:09 PM
Paul Bell's Avatar
And welcome to LS1Tech.
Go to your user control panel and create a signature showing what car you have. This way, you won't need to tell everybody what it is in every post.
Old Aug 24, 2011 | 09:42 AM
epg_xtony's Avatar
Alright will do. Thank you, I'm using my phone so once I get around to getting home ill make a Sig. But what I'm saying about the power is even if i open the door it stays on....indefinatly.
Old Aug 24, 2011 | 10:01 AM
Paul Bell's Avatar
OH. Yes, then something is wrong. Check this also: When you open the door, do the interior lights come on?
Old Aug 24, 2011 | 03:48 PM
epg_xtony's Avatar
Yup they come on and go off like they are supposed to
Old Sep 10, 2011 | 05:25 PM
pemberton's Avatar
I am having this problem to, my battery actually died cause I didnt notice it at first. I resoldered the T on the BCM this seemed to fix it but for only about two weeks. Its got to be a problem with the BCM or door sensor, cause I also do not have interior lights when I open the door.
