center console and gear shifter removal
I'm trying to remove the center console....I've taken out all the visible bolts but still can't seems to get it loose enough. How do I go about removing this piece....and i'll have to remove the gear selecter as well and would like to know the best way for this as well.....thanks.
1) Remove two bolts where the console meets the dash.
2) Remove the shift ****.
Set Parking Brake, pull lever back to 1 or 2. Pull retainer out with a small pick or screwdriver from the front of the ****. Pull up/off ****.
3) Remove the coin holder by pulling straight up. Remove two screws that were hidden under there.
Pull upper section of the console off.
Make sure you unplug the lighting & stuff that you find connected under the console.
True, ...
