Power steering bleeding issue
I then went through the process of bleeding the system.
1 - filled reservoir with PS fluid, prestone. Didn't have enough so then added some NAPA power steering fluid (it's blue).
2 - lifted front wheels off the ground, and turned wheels back and forth about 20 times, making sure to hit the stop each time. I noted that I didn't need to add very much fluid.
3 - I stared the engine, with the wheels still up in the air, and did the same thing, turning the wheel back and forth a number of times. I noted that the steering wheel was pulsing as I was turning it, and that eventually went away. Noted that I didn't need to add any additional fluid (cap was off all the time). Pump was noisy, but that went away.
4 - let the engine sit overnight, with the cap still off to allow any more air to bleed.
5 - This morning, checked the fluid level and it's still the same. Started the car and the pump was whining. Move the car forward and backwards while turning the wheel stop to stop, and I felt it pulsing on several occasions. Would whine from time to time, but not consistently. One thing I noted here is that the fluid was very hot (couldn't hod my hand on the reservoir). I only had the car running for less than 5 minutes. I was getting power assist, but not consistently. It was working fine before I swapped out the pump (thinking that the rack was working fine before the swap).
6. Shut it off, and the fluid level hasn't changed.
Here's the questions. I've used two different brand of regular power steering fluid. Is that a problem? I did not flush the rack. Is that a problem?
Why is the fluid getting so hot? I'm guessing that I still have air in there and have to start the bleeding process over again with the wheels up in the air. Any additional thoughts or suggestions?
Thanks
With everything hot, I'm unable to get the pulley off using the collar-type pulley puller. So, the shaft movement is not the pulley, but the pump shaft. Once it cools down, I'll try and get the pulley off and confirm the shaft problem. Looks to me to be a bad pump. I still have the original pump, and since the leak was from the failed o-ring between the reservoir and the pump, I'm thinking that I'll re-install the original and see what happens.
Any thoughts?
I noticed that the O rings in both the pressure and return line where a little chewed up. Put them back in but will replace them ASAP.
After the pump has been on for almost a month now, while everything seems to be working and no leaks, the pump remains noisy (kinda like a ford), the steering effort is a little harder but I don't mind, but I detect a slight pulsing in the steering wheel. What do you folks think?
