Sponsored by: CARiD
Cleaned engine bay, now regulator issue.. fml
Old Sep 18, 2011 | 07:04 PM
stephen4036's Avatar
Originally Posted by 02ws.sik
if it dosen't sputter try your coil pack and let it sit with the hood up over night in a garage or get a leaf blower and blow it off for 30 mins.
already did the leaf blower thing, and its been 24 hours, I think the water wouldve been gone by now..
Old Sep 18, 2011 | 07:09 PM
02ws.sik's Avatar
try to look at all the fuze see if they are blown.
Old Sep 18, 2011 | 09:17 PM
would a fuse really cause all this? wouldnt it just cause what ever said fuse is running off to fail?
how do u tell if a fuse is bad.. you cant always tell if the peice if broken off
Old Sep 18, 2011 | 09:19 PM
02ws.sik's Avatar
Is their a check engine light?
Old Sep 19, 2011 | 09:18 AM
no there is not
Old Sep 19, 2011 | 10:04 AM
macknmikey's Avatar
not sure what tests autozone run on alternators but id still go with a bad alternator
Old Sep 19, 2011 | 10:30 AM
well problem is fixed.. woke up today and shes at 14volts.. guess there so much water in it that it took a couple days to go away..
thanks for all the replies.
Old Sep 19, 2011 | 10:31 AM
Calvertcm2003's Avatar
Id go with bad alternator as well. I had this happen once after it rained quite a bit and it started overcharging. Pulled the connector from alternator the one with small fragile wire attached and socket in alternator had water in it. Stuck a paper towel in socket to dry up water and made sure plug didnt have any water in it. Plugged it back in and was good to go. But since you have already had alternator out there shouldnt be any water in socket on alternator.
Old Sep 19, 2011 | 10:33 AM
macknmikey's Avatar
good deal
Old Sep 19, 2011 | 10:45 AM
LS6427's Avatar
ok, well ive never had a problem on any previous vehicles of just spraying simple green everywhere then hosing it off.. well i get in the car to go somewhere and the headlights are pulshing, the dash and all interior lights are pulsing.. and the volts on the car are at like 18.. and if im sitting still at a light its like 15.. had to go to advanced anyway to get the gas cap and so he said it was high revoltage and the battery is fine.. so im guessing its the regulator?
1. is the regulator inside the alternator on an LS1 car?
2. is there anything I can do to try and dry or repair it..?
3. how hard is it to change an alternator if I did **** it up?
Don;'t change anything........its normal to have those issues after spraying the engine bay with water. It has nothing to do with the alternator. You got the electrical stuff wet. This happens to me every time I clean my engien bay....it will dry up on its own and go away.
Next time it happens all you have to do is drive around with your headlights on, fog lights on and A/C fans on high....rear window defroster too if you have it....that should keep the charging out of the red while its drying. It works for me.
Old Sep 19, 2011 | 01:03 PM
02ws.sik's Avatar
next time cover everything up lol.
Old Sep 19, 2011 | 01:04 PM
  #32
lol im just gonna wait till i do cam/ls6 intake and then get in there like a dirty bitch and clean it up
Old Sep 19, 2011 | 05:46 PM
  #33
myk's Avatar
myk
Huh?
The problem is over-charging, not bad engine performance. Spark plugs and coil packs have nothing to do with electrical charging performance. Also, even if he used a fire hose water would not get into a spark plug hole if the plug was on there properly.
I must be on something or some of the answers in this thread are just plain weird...
