Sponsored by: CARiD
Cleaned engine bay, now regulator issue.. fml
Old Sep 17, 2011 | 10:53 PM
stephen4036's Avatar
Default Cleaned engine bay, now regulator issue.. fml
ok, well ive never had a problem on any previous vehicles of just spraying simple green everywhere then hosing it off.. well i get in the car to go somewhere and the headlights are pulshing, the dash and all interior lights are pulsing.. and the volts on the car are at like 18.. and if im sitting still at a light its like 15.. had to go to advanced anyway to get the gas cap and so he said it was high revoltage and the battery is fine.. so im guessing its the regulator?
1. is the regulator inside the alternator on an LS1 car?
2. is there anything I can do to try and dry or repair it..?
3. how hard is it to change an alternator if I did **** it up?
Old Sep 18, 2011 | 12:08 AM
20 views no suggestions? come on guys
Old Sep 18, 2011 | 03:27 AM
kdoublep's Avatar
I always dry mine with a leaf blower and leave it in the sun with hood open until dry before starting it. I disconnect battery and I zip tie plastic over all exposed sensitive areas as well (intake alternator, etc.). I know this seems elementary, but it helps for future.
Try air compressor as well t dry it around electrical areas.
Make sure your fuses, relays didnt get wet under the hood. Make sure boxes were sealed properly. Moisture in ther can cause problems. Try air compressor as well to dry it around electrical areas, fuse/relay housings.
All I got right now.
Old Sep 18, 2011 | 09:29 AM
wssix99's Avatar
Save the manuals!
Inside the alternator.
A repair requires an alternator rebuild.
Pretty easy. Do it from underneath the car. (Putting it up on ramps is just fine.) Remove the belt, unplug it, unbolt it, and you should be able to rotate and twist it in a way that it will come out. You can then take it to a parts store to be tested.
When you do this - be warned that the exciter wire is very fragile. (Its the thin red wire that goes in to a plastic connector on the alternator.) If you let the alternator drop on this wire, bad things will happen. If you can disconnect this wire first with a hook, screwdriver, etc. you'll be in good shape.
Old Sep 18, 2011 | 04:53 PM
Update:
took the alternator out, took it to autozone.. passed all test or whatever.. the car is still over charging.. it sits at 18volts.. if i rev it goes goes down a couple and the lights just pulse and whatnot.. what else could this be guys.. what are some other spots i could check to see if they are still wet?
Old Sep 18, 2011 | 04:56 PM
02ws.sik's Avatar
Try a new battery
Old Sep 18, 2011 | 04:57 PM
Originally Posted by 02ws.sik
Try a new battery
any reason behind this?
Old Sep 18, 2011 | 04:58 PM
02ws.sik's Avatar
Its worth a try isn't it. Just pull one out if you have another car and put it in.
Old Sep 18, 2011 | 05:00 PM
needs to be the same cranking amps and whatnot though doesnt it..
Old Sep 18, 2011 | 05:05 PM
02ws.sik's Avatar
Im talking about the battery. My dads truck did what yours was doing and we got a new battery and plug it up and it was fine
Old Sep 18, 2011 | 05:51 PM
just took the battery to autozone.. tested fine...
what else? something is obviously fried/not working.. if it was just water it would have dissapated by now.
Old Sep 18, 2011 | 06:16 PM
02ws.sik's Avatar
have you checked all of the fuzes check the fuze box under the hood make sure their is not water in there
Old Sep 18, 2011 | 06:20 PM
yup, took the covers off, looked, check the computer connections, no water in there either.. im totally ******* lost.
Old Sep 18, 2011 | 06:44 PM
02ws.sik's Avatar
i just called jamie. He said it must have water in the spark plug holes. He said its no big deal take out the sparkplugs and let it dry with the hood cracked open.
Old Sep 18, 2011 | 06:45 PM
motherfuck.. arent spark plugs a total clusterfuck on these ls1 cars?
Old Sep 18, 2011 | 06:46 PM
02ws.sik's Avatar
Also said could have water in your coil pack. so its something with your ignition. It will run and sputter right?
Old Sep 18, 2011 | 06:47 PM
02ws.sik's Avatar
no why i have never had a problem knock on some wood.
Old Sep 18, 2011 | 06:48 PM
02ws.sik's Avatar
this wasn't with a pressure washer was it?
Old Sep 18, 2011 | 06:50 PM
runs perfectly fine.. just sits at 19volts and the headlights and gauges pulse..
no, just a hose.
Old Sep 18, 2011 | 06:55 PM
02ws.sik's Avatar
if it dosen't sputter try your coil pack and let it sit with the hood up over night in a garage or get a leaf blower and blow it off for 30 mins.
