Sponsored by: CARiD
P0175 Engine code
Old Sep 17, 2011 | 11:17 PM
_Silver_'s Avatar
Default P0175 Engine code
P0175 engine code, system too rich bank 2. Can any one tell me exactly what this means?
Old Sep 18, 2011 | 12:40 AM
RsSean's Avatar
means that the right side of the motor-passenger side is rich- to much fuel, not enough air, not enough spark misfire on that side.
Old Sep 18, 2011 | 08:32 AM
_Silver_'s Avatar
Default Any suggestions
Any suggestions on how to fix this myself? Im new at all this and trying to figure it out myself. Or should I take it to a shop?
Old Sep 18, 2011 | 08:35 AM
_Silver_'s Avatar
Default Need Help
Any suggestions on how to fix this myself. Im new to this and trying to fgure it out on my own. or should I take it to a shop?
Old Sep 18, 2011 | 10:48 AM
wav3form's Avatar
I just google searched the code... maybe this can help you out.
Causes
A code P0175 may mean that one or more of the following has happened:
The MAF (Mass Air Flow) Sensor is dirty or faulty. Note: The use of "oiled" air filters can cause the MAF to become dirty if the filter is over-oiled
There could be a vacuum leak.
There could be a fuel pressure or delivery problem
Possible Solutions
Possible solutions include:
Inspect all vacuum and PCV hoses, replace if necessary
Clean the MAF sensor. Consult your service manual for it's location if you need help. I find it's best to take it off and spray it with electronics cleaner or brake cleaner. Make sure you are careful not to damage the MAF sensor, and make sure it's dry before reinstalling
Inspect fuel lines for cracks, leaks, or pinches
Check the fuel pressure at the fuel rail
Check the fuel injectors, they may be dirty. Use fuel injector cleaner or get them professionally cleaned/replaced.
Check for an exhaust leak before the first oxygen sensor (this is unlikely to cause the problem, but it is possible)
Old Sep 18, 2011 | 02:53 PM
96SilverZ's Avatar
I would check your injectors and see if they are leaking.
Old Sep 18, 2011 | 06:23 PM
LS1121's Avatar
check all of you vaccum hoses and the electrical connections, could be that simple. How does the motor run, is it missing? and i don't mean is it still under the hood. lol
