Idle issues, and few codes pulled
swapped into a 1979 chevy k20 truck.
mated to a th350/203
the problem im running into here is whether the motor is hot or cold, when i start the truck, the idle shoots way up to 2000 rpm, for about 30 seconds, then gradually comes down to 1500, and over a period of 2 minutes or so it will settle at 800 when its warm.
Update: also found i had two codes that just came up the other day, truck was running great besides the idle issue, then on my way home just before the house i got check engine light, p0172 and 175. both banks are to rich.
My brothers laptop (autotap hookup) is telling me desired engine speed is 600 rpm, which im not seeing.
i believe it was the IAC or MAF counts were reading 0 at idle is this normal?
and my dakota digital VSS converter is reading 6-9 mph just sitting still in park.
i have replaced intake gaskets thinking it could be the problem, but cant find a vacuum leak.
did some work on the scanner today, found out, those two codes, MAF was reading around 11.8 lbs? dont remember what scale it was reading. vss was reading 3-5 mph,
Bank one was reading -15- -19 % i believe
Bank two was reading -15- -31 % ( smoking only on bank two)
I wouldnt think this would be a vacuum leak considering that the ECM is trying to lean it out, but not doing so great. (at running temp). if it was a vacuum leak i would think it would be a lean condition not rich.
any input would be appreciated. thanks
also the MAF Came down to spec (4-6) lbs a min i believe.
