Sponsored by: CARiD
Engine coolant light
Old Oct 3, 2011 | 02:09 PM
tbarks53's Avatar
Default Engine coolant light
I'm a noob to the f body's.
I bought a 98 z28 ls1 bolted to a m6 about 2 weeks ago. I've checked all my fluids and stuff but my engine coolant light won't go off. Any suggestions?
Old Oct 3, 2011 | 03:51 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Replace the sensor
Old Oct 3, 2011 | 03:53 PM
6speedt/a's Avatar
It's the coolant level sensor it's on the drivers side of the radiator under the upper hose. You can take it out and clean the crap out of it of just leave it disconnected that will fix it
Old Oct 3, 2011 | 04:09 PM
mike171562's Avatar
unplug it
Old Oct 3, 2011 | 05:11 PM
HuggerOrangeZ's Avatar
I unplugged mine, then plugged it back in and it stayed off. That was 7 years ago.
Old Oct 3, 2011 | 09:15 PM
SOMbitch's Avatar
It's 3"-4" under the radiator cap on the PS....
EDIT: you'll see the wire and plug that run to it.
Old Oct 3, 2011 | 09:36 PM
JaYZeig's Avatar
check the connector to see if its growing anything inside..like corrosion or anything. thatll do it too.
Old Oct 4, 2011 | 11:53 AM
DWake's Avatar
Another vote for unplugging the sensor
By Brett Foote | 2026-06-04 05:00:17
