- Camaro and Firebird How to Replace Power Window Motor<br>Step by step instructions for do-it-yourself repairs.
Driver power window motor slow
There is a lot of resistance in the circuit, so the autotrix kit will give a more direct path to the 14V that the alternator puts out and will help hide a gimpy motor. It "fixes" nothing. It will just make a bad motor look better.
If you replace the motors with quality ones, you'll get consistent and good performance.
Rivets (and a special industrial sized riveter) are necessary if you replace the regulator and have to make the regulator to door connections.
