Sponsored by: CARiD
Power Steering Pump Leak
Old Oct 23, 2011 | 08:37 AM
BlackBirdDaddy's Avatar
Default Power Steering Pump Leak
I just completed my LS2 conversion and after firing it up I noticed a leak at the power steering pump. I had removed it checked everything replaced it installed dual clamps on the return line on the pump, started it and still dripping.
Is there some sort of seal/o-ring between the reservior and the pump?
Thanks
Old Oct 23, 2011 | 09:14 AM
wssix99's Avatar
Save the manuals!
Yes, there is a special O-ring. I couldn't find a match at any parts store or hardware store and ended up getting one from a pump rebuilder.
Did you put the pump together yourself? I understand that pumps usually come with one in the box if the unit isn't put together originally.
Old Oct 23, 2011 | 09:58 AM
No, actually this is a used pump that I acquired. I am going to tear it apart today and see if I can find that o-ring. Thanks for the help!
