Sponsored by: CARiD
ac clutch
Old Oct 23, 2011 | 05:45 PM
Dainius56's Avatar
Default ac clutch
So for the past few days I have been hearing a kinda grinding noise every 3 seconds under the hood. Noticed when ac is off the clutch tries to spin slowly when making the noise. I had replaced the clutch about 5 months ago and was told there was no air gap for this car but just to tighten it down all the way. Sooo, question is, do I need to pull the clutch out just a hair? I believe it is catching on the pulley and making that noise. Or am I just hoping its that easy and something bigger? BTW, it makes no noises when AC is on.
Old Oct 23, 2011 | 07:31 PM
wrencher's Avatar
wrencher
There has to be an air gap. That's how it disengages the clutch.
I cannot remember the exact spec. It is usually around .018-.024"
Old Oct 26, 2011 | 11:26 AM
LS14EVR's Avatar
agreed! air gap is needed. IT's a delco. and I just did the delco on my suburban. 0.020 should get you close.
Old Oct 26, 2011 | 01:41 PM
macknmikey's Avatar
i just quesstimated my gap and ac works perfectly no squeeks squeels grinds or hooligans
Old Oct 30, 2011 | 07:43 PM
FiredUpZ28's Avatar
I'd just put a compressor on it. Replacing a clutch never works out. Sometimes you can get it but if not it can be a pain.
