Are all four o2 sensors the same?
I'll make it easy....measure how much length you need for whatever position you need a new sensor for......if 16" is long enough, including tucking it behind heat shields and/or keeping the wire away from anything hot, etc.....buy Denso #2344025. Done.
If you need more wire length, Bosch is an option, or wire extensions. I would go with extensions and use the Densos personally.
denso 2344087 upstream right, denso 2344025 upstream left.
I forget which side had the longer wire length, but they replaced what was stock in terms of wire length exactly.
2002 camaro
