HVAC blower motor issues
I just got done installing it and yet it still doesn't work. I've checked the fuses under the hood and also the fuses on the inside. I used a test light on the connector at the blower motor. There was no power at the large purple wire.
I then removed the HVAC plate and checked all the wires going into the speed control. I believe it was the yellow or tan wire that had power going to it. So I'm thinking it's got to be the resistor, or the blower motor relay. I ust don't know where these parts are though.
So for anyone searching, the relay is behind the radio closer to passenger side.
