Sponsored by: CARiD
what does this do behind the steering wheel??
Old Nov 29, 2011 | 02:52 PM
notnilc20's Avatar
One more thing....the connections that I circled in the photo....are those prongs for the horn or what?? Not the copper color rod that I have an arrow pointing to. Thanks.
Old Nov 29, 2011 | 04:40 PM
wssix99's Avatar
Save the manuals!
They are just terminal ends for components of the turn signal switch. Nothing you need to worry about.
BTW - You should check out this thread and lubricate your turn signal parts (where metal contacts plastic - you'll see the old discolored white grease) so your turn signal will be smooth. You can only do this when the column is taken apart like you have it. https://ls1tech.com/forums/general-m...d-blinker.html
