Sponsored by: CARiD
Need a new maf
Old Dec 3, 2011 | 06:12 PM
bad_408_vert's Avatar
Default Need a new maf
Could a bad maf not let my car start? If I unplugged it, car fired.
Ses light is on code p0120
If I need a new maf is it really necessary to get acdelco brand?
Thanks!
Old Dec 3, 2011 | 07:39 PM
chrysler kid's Avatar
yep you need a new MAF. autozone has them for $139 they are refurb units
Old Dec 3, 2011 | 09:06 PM
sjsingle1's Avatar
i got the new plastic style..........GM no longer makes the original metal 1s.............off of ebay cheap...........ac/delco
Old Dec 3, 2011 | 09:51 PM
can someone confirm that this could likely cause the car to stall.
when it stalled last night, the rpm needle was going up and down.
Car also acted like it was starving for fuel.
I confirmed that fuel-pump is good and put a new relay in.
Old Dec 3, 2011 | 10:05 PM
bluenightmare's Avatar
yes as chrysler kid says, you need a new maf.
the M.A.F or Mass Air Flow sensor detects the density (mass) of the air coming into the intake (flow), and it tells the pcm how much fuel to put into the cylinders. If the maf is telling the pcm the wrong reading you will not get the correct air/fuel mixture for combustion. You have already trouble shot it by unplugging it. Time for a new one.
Old Dec 3, 2011 | 10:41 PM
ok thanks guys. Pickin up a new MAF in the morning. BTW Advance Auto is the best
