Sponsored by: CARiD
Heater Core Replacement How-To?
Old Dec 22, 2011 | 06:46 PM
LS1C5Vette's Avatar
Default Heater Core Replacement How-To?
Is there one. I cam smell antifreeze with my heater running so I take it my heater core is bad, I have no other leaks under the hood.
Old Dec 25, 2011 | 12:13 PM
LS1C5Vette's Avatar
bump...
Old Dec 28, 2011 | 08:55 PM
ZeeTwentyFate's Avatar
tear dash out, pull core, replace core, re install dash. lol its easy once you get into it, just time consuming.
Old Dec 29, 2011 | 05:52 PM
joecar's Avatar
Does the inside of your windshield fog up with coolant (you will know it is coolant when you try to wipe it clean)...?
The heater core comes out from the glove box cavity after you disconnect the two hose clamps from the other side of the firewall.
(i.e. you only need to remove the glove box)
