power steering cooler hose
I have searched through dozens of threads and I am still confused. I am trying to identify the hoses that connect to the factory power steering cooler. The picture shows they are both fastened by clamps.
Which one is the return and feed line? I have an aftermarket cooler and the hose that was connected with a barb fitting (steering rack to cooler) keeps leaking at the barb. I have tried different barbs, clamps, and there is still a leak. I am thinking I need a new hose.
So is the return line the one that connects the power steering cooler to the fluid reservoir or is that the feed line?
The return line to the reservoir is simply the line that goes to the bottom of the reservoir. If you have that factory cooler, it will go from that cooler to the bottom port on the reservoir.
Get rid of that factory cooler......
The metal line coming out of the pump on the passengers side is the high pressure line that feeds the rack.
I can't of any reason why the hose should leak if you have a properly sized barb and a good screw-type hose clamp on there. (I recall that my rail cooler came with different barb sizes.)
http://www.oreillyauto.com/site/c/de...2846&ppt=C0031
This is the only high pressure hose that shows up at O'Reilly's. The attachment is from 1stpontiacparts.com. Would it be number 14, but that says its the return line.
What kind of aftermarket cooler do you have. A leaking connection at the aftermarket cooler is a common issue and you'll have to match the barb to the hose size. If they aren't matched properly, you'll never get a seal.
If you have a small transmission cooler with small lines, it may not work for you. Proper fluid coolers should come with different barb options to match the hoses. You'll need something that will take a 5/16 or 11/32 ID hose for this job.
If someone that still has their stock cooler and hoses attached on their car can measure the hose for me, it would be greatly appreciated.
I took the #14 hose, disconnected it form the stock cooler, and cut it short to fit the location of the cooler. I then used the additional piece of hose that came with the Perma Cool unit to connect the new cooler to the reservoir.
I don't remember the length of #14 because I cut it. On the older cars that didn't come with stock coolers, the same hose was used. Instead of connecting the rack to the cooler, it just connected the rack to the reservoir. (When GM added the cooler, it was very easy for them. They just kept the same hose and just needed to add a small hose to connect the cooler to the reservoir.)
