Need fix for window guide
The rivet hole for this window roller guide enlarged and split downwards vertically, so now the rivet won't seat in this plate thats attached to the bottom of the window. The window now slides back and forth freely inside the door unless it's up all the way. - who's seen this.. ideas?
thanks!
damaged hole
OEM slider assembly in rail
my fabbed replacement
screw is 1/4-28 tapered head socket head cap screw,thick washer(well greased to minimize metal to metal contact) used to duplicate large roller and has a ID larger than the screw to allow 'swivelling',large thin flatwasher to prevent pullout thru the damaged hole,1/4-28 locknut.
The textbook solution is to replace the door channel. An alternative is to take the car to a body shop and have them weld the post back in.
If you weld, watch out for the pitfalls:
- If things get too hot, the glass could shatter. (I haven't seen any people who welded report this.)
- If things get moderately hot, the roller could melt. (The rollers were made to pop off the posts, but age may have made the plastic too stiff to do that. If you leave it on, the welder just needs to avoid it with hot stuff and going slow or using a heat sink will help.
The window on my 01 TA just stopped moving. Won't go up or down and the window flops around left to right, so was thinking this could be it. Haven't taken the door apart yet. Doing some preliminary research. Thoughts??
Any help is appreciated.
