Sponsored by: CARiD
no start need advice asap
Old Jan 26, 2012 | 05:52 PM
1998 candy camaro's Avatar
Default no start need advice asap
i have 1998 camaro ls1 just spins over i checked the coil connector with test light it has fire but want fire the plugs plugs dnt even smell like gas so i guess the injectors not firing off either changed the cks still have nothin can someone help me asap
Old Jan 26, 2012 | 09:01 PM
513camarors91's Avatar
first i would check to make sure that you can here the fuel pump kicking on and if so then i would get or borrow a noid light tester to test the injector wires to see if they are getting the signal to fire them.
Old Jan 26, 2012 | 09:32 PM
94'BLKBRD's Avatar
Check the fuel pressure.
