Changed my spark plugs today, even #8 LoL
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
Changed my spark plugs today for the first time. Took a few hours, got #8 from up top. Taking off the coil packs on the passenger side definitely helps.
Had to lay on top of the engine compartment to get some out lol.
I wore something to cover my arms so I didn't get cut up too bad![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
I checked the gap on the plugs and most of them were over .060 (see pic).
It wasn't as bad as I thought it would be, so if your on the fence whether or not you should do it yourself go ahead and do it !
The cowl didn't get in my way too much. Getting that last bolt out on the coil pack and the passenger side plugs could scrape your arms up. If they would of used anti-seize when they put the original plugs it would of helped too.
