Removing rusty/broken manifold studs
I drilled it out just a tad bigger than the stud and used a bolt with a nut on the top side.
I think you can get your hands and tools to the nut if you put it on the manifold side.
If that doesnt work, torch the **** out the exhaust, spray pb and guerrilla grip a vice grips to the stud and try turning it that way.
If those methods fail, cut/drill/torch it off.
