LS1 Leak
I would hammer the entire area with a good degreaser and get it shiny clean everywhere. Then drive it for awhile and see if you can better locate the source of the leak.
If you can find Formula 88....that stuff is amazing. Cold engine, it'll shine. Home Depot has it here.
I would clean everything. Then tighten down those coolant line bolts on the heads and maybe even snug down the valley cover bolts...can't hurt. Also, change that factory clamp on that rubber hose for a screw type clamp.
