Service Engine Soon
Will having no cats affect the performance of the car? I just want to know if the 2nd o2 sensor will mess with the air to fuel ratio and make the car run lean etc...
Knock sensors are fairly common issues, I would also replace your fuel filter and spark plugs while you do the knock sensors.
I made a day out of removing my intake manifold by cleaning everything while I removed parts. I would suggest using a shop vac to suck dirt out of the valleys around the intake manifold before you remove it just to prevent dirt from getting into the valces
That helped alot
