Sponsored by: CARiD
Old May 13, 2016, 03:14 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Chevrolet Camaro or Pontiac Firebird Specifications & General Maintenance
Print Wikipost
LS1 Maintenance Suggestions
Old Feb 25, 2012 | 09:21 AM
DBurgLT1's Avatar
Originally Posted by LS6427
Hell yea......
It was so bad the tire alignment guy said there's no way he can align it...lol
That is exactly what I was told as well. lol
Old Feb 25, 2012 | 09:27 AM
LS6427's Avatar
Yup.....rebuilding the front end.....new upper and lower arms....tie rods, bushings, end links and my rebuilt 9 year old shocks.
It was the only repair I've ever done where I was literally speech less after I went for a ride.
Its so overlooked...the years go by and you don't realize the gradual degradation.
Old Feb 27, 2012 | 01:31 AM
chrysler kid's Avatar
Denso 02 sensors. Rockauto.com or amazon should be $40 each
Ngk tr555 spark plugs from oreilleys
Cheapo spark plug wires from autozone
Fuel filter from oreilleys was $8
As mentioned the o2's dont need to be replaced at a specific mileage however if you are going to make a day out of it you may as well knock them out and keep the old ones as a spare set.
Do not get a k&n filter. Get a cheapo Fram as the k&n are way too oily for our mass air sensors.
If you plan on keeping the car a while you may want to go ahead an order window motors
Old Feb 27, 2012 | 04:42 PM
DNTBJELOUS's Avatar
Got all my parts in today and will be doing my plugs and fuel filter sometime this weekend if I have time. I want to run this tank with seafoam in it through then put it in my crank case after. See how it runs then.
Old Feb 27, 2012 | 06:55 PM
I'm not thrilled with seafoam, you could be doing more harm than good to your engine seals. However there are Several different opinions on it
Old Feb 28, 2012 | 09:17 AM
Rare96LT1Formula's Avatar
Hell yea......
But to have ball joints and bushings changed in factory upper and lower control arms.....it'll cost you more than $500. Its HELL to change them. I bought two upper and two lower arms on this forum that were in new condition....$45.00.
I did all new bushings and ball joints for my front end last year....after 200,000 + miles on my car.......jeez it was like a brand new car. It was so bad the tire alignment guy said there's no way he can align it...lol Its such a slow process of degradation that I didn't realize how terrible it was.
Of course though, I had to rebuild my QA1 shocks and I bought new Bilstiens for the rear.
Change radiator hoses before they pop or split. Including the coolant crossover line and overflow tank fill line.
Dump a full can of SeaFoam into 1/8 tank of gas and run it out....THEN change the fuel filter.
Regarding 02 sensors......they either work or they don't. Don't waste the money on them unless they are failing. Only a scan can tell you how they are working.
Drain all the brake fluid and replace it completely. Make sure its done right WITHOUT running the master cylinder dry.
Top end cleaning..........DO NOT USE SeaFoam. Use MCCC (Mopar Combustion Chamber Cleaner). If you can't find that......make sure you use a TOP END CLEANER.....NOT SeaFoam.
If its never been done.....You should really take the A/C condensor out and have it professionally cleaned.....I'm talking about the outside of it. This will require a new A/C charge, but most A/C shops will capture your old and put it back in when you're back together.
Clean the radiators exterior too........
MUCH better engine cooling with a clean condensor and radiator.
Bulbs are cheap....change all the tail light bulbs. Mine were actually dark and burned but still not blown. I changed mine on one side last week......holy brightness batman. I thought I had some other issue. Just darkened bulbs........
Best advice in the entire thread. LS6427 helped instruct me to clean out my intake with the MCCC he mentioned when I first bought my LS1. You wouldn't believe how much oil and carbon deposits that stuff cleared. I noticed an improved idle/throttle response and literally 2 mpg's better!! You'd be amazed how much basic maintenance helps these cars. I've been looking into rebuilding my entire suspension this summer with MOOG bushings,etc.
Clean your MAF
Clean your TB (remove from intake and clean it good!)
Clean your intake
Plugs/Wires/Fuel filter/Air filter
Old Mar 2, 2012 | 10:09 AM
DNTBJELOUS's Avatar
Just ran the sea foam through my gas tank. I checked my gas mileage and got 20.5 MPG. Going to then do it through my crank case and then vacuum lines next maybe this weekend if I got time. I figured I'd hold off on doing the plugs, air filter and fuel filter till I do all of that getting the gunk out.
Old Mar 3, 2012 | 10:45 PM
beyonddisturbed's Avatar
My plans over the next couple months.
Fuel filter
Diff Fluid
Trans Fluid
Plugs/Wires
Flush Brakes
Clutch fluid-also lookin at a tick master/slave
Old Mar 4, 2012 | 07:27 AM
jam01's Avatar
K&N's are garbage....all they do is make your MAF dirty and then your performance is decreased more and more from that point. Regardless of what anyone says.......The oil that goes onto the K&N filters comes off if its foggy out, rainy out or if you go for a drive on wet roads after it rains. FACT. It reactivates the oil and makes it shed from the K&N filter. It goes right on the MAF and coats it with that crap oil.
Does the engine just run like crap...NO. But its ever so slightly killing performance little by little.
Leave the K&N's to road racers, they can barely oil it, still keep the big chunks out and have a little better flow. But they don't care, they rebuild engines 5 times a year.
And they DO NOT protect your engine from small particles as good as a paper filter, not even close. More airflow getting through = more dirt getting through also. Power gains claimed by K&N....all bullshit lies. You cannot put a car on a dyno, do two back-to-back pulls at the same engine temp and get two identcial HP/TQ numbers. IMPOSSIBLE. All they do is keep doing dyno pulls until they see a higher number, then they tell everyone, "Hey, we have a 5 HP gain." Its bullshit......
Do yourself a favor and get a Mann air filter. Best one out there. Protect your engine properly and give up that .0000001 HP increase K&N claims.....
only the mechanically challenged over oil the filter ive been using these filters since the early eighties and i have never had the problems this guy claims. as far as there h/p claims i have never cared about having it done.
if i lost the race then i rebuilt.
