Sponsored by: CARiD
bad radiator cap or overheating?
Old Feb 28, 2012 | 03:24 PM
sheaadams86's Avatar
Default bad radiator cap or overheating?
I can hear hissing like coolant is going out the overflow tube after I turn car off, gauges showing no signs of overheating
Old Feb 28, 2012 | 05:31 PM
Johnnystock's Avatar
Try the cap for 10$..after, check your coolant sensor level or temp sensor or thermostat LOL
Old Feb 29, 2012 | 02:09 AM
bww3588's Avatar
Rent a radiator pressure tester and a leak down tester. Test the cap, cooling system then check the engine.
Old Feb 29, 2012 | 07:16 AM
chrisfrost's Avatar
It's not over-heating yet if the gauge says it's not but a bad cap will cause it to over-heat at some point probably more sooner n less later ,,,,,,,,x2 for what Bww3588 said . The only way fluid should be exiting the cap is if it was just filled and it was over the normal point it will level itself to after 1 or 2 warm-up cool down cycles or it was driven really hard ,,,,,,enough to raise the temp above normal operating temp or the cap is bad or a combination of any of those .
Old Feb 29, 2012 | 10:45 AM
LS6427's Avatar
Get a $4.00 Stant cap.......yours is probably just old and not holding your pressure anymore. Very common issue and overlooked allot.
