PITA air in cooling system
That's the weird thing, no I didn't have an air pocket and the radiator. Before getting in this pile that I'm stuck in now, I never had a problem with over heating. But since I have started the process (read like 4-5 times) I have not been able to get it right. I work 3rd but I might say F sleep and go try again since it is supposed to be nice today...
Oh and as I was filling radiator, it would over flow. It actually filled up the over flow tank. So I had to get and old syphon and get it back to where it needed to be.
Cold engine:
You need to remove the t-stat from the t-stat housing, then bolt the housing back onto the water pump.
Top off the coolant in the radiator, leave the radiator cap off, start the engine, top off coolant again if needed.
The coolant should flow IMMEDIATELY...........if it does flow......go get a new t-stat, its sticking and not operating properly all the time.
So I ended up pouring coolant in tie upper hose and that seemed to do it...so I guess that next to nothing was in the block...it took almost a whole gallon. Idled and cooled twice, topped off and went and kicked the car around town...will check again tomorrow.
Lol, yeah I just hope it stays that way so I can move to more important things... like repacking all my idlers and tensioner pulleys to get rid of this god awful chirp/squeak I have had since the end of last season.
