LS1 starting problem (Clicking then starting)
I have also had another problem for the last couple years but it is more of a bother than a problem. When I go to start the vehicle, it turns over but does not start. You can hear it trying to start and it won't start unless I give it some gas.
If anyone can point me in the right direction I would appreciate it!
-VortecLS1
As for the not turning. Can you hear the fuel pump prime? If you turn the car to accessory 2 or 3 times will the car on fine?
Thanks again
-VortecLS1
-VortecLS1
