Sponsored by: CARiD
My first Fbody
Old Mar 3, 2012 | 03:51 PM
Myersws699's Avatar
Default My first Fbody
I recently purchased my first firebird. 1997 Firebird Formula WS6 which I have heard is 1 of 473 formula ws6 combo made in 97. I have a couple issues going on that I really need advice about what I need to do before it gets worse. First, is the noisy rear end. It starts at 45mph and gradually gets louder. I have heard that it is just a firebird thing, but I am not sure as speed increases it sound like a multi tone wah wah sound, when I press the clutch it stops. 2nd the transmission makes not a loud grinding noise but a mild rattle when I get going in first gear. It doesn't do it the whole gear just about a second or so. Also when I press the clutch to shift in hear a pop but only when shifting to 2nd and 3rd gears... It hasn't ever grinded or had trouble going into gear. And third when it is warmer outside when I open the gas cap, it has pressure in the gas tank... Any advice or information will be greatly appreciated!
Old Mar 3, 2012 | 03:55 PM
Myersws699's Avatar
Also I forgot to add that the oil has been changed every 3500 miles with Mobile 1 Synthetic, the whole car is FLAWLESS and this is what confuses me so bad because of the condition its in!
Old Mar 3, 2012 | 05:32 PM
ULTIMATEORANGESS's Avatar
these rears suck. depending on how much power you make or want to will determine if you want to upgrade to a better one.
sounds like something in your trans needs repair.
your gas tank problem ive never heard about.
Old Mar 3, 2012 | 06:21 PM
Myersws699's Avatar
I have heard it could be a bushing but I don't have a clue
Old Mar 3, 2012 | 06:34 PM
z28clark's Avatar
My 96 z28 did the same thing with the tank. Found the vent hose and my evap lines were bad at the tank.
Old Mar 5, 2012 | 06:06 AM
Myersws699's Avatar
Anyone else? Will the transmission get noisy when it needs a fluid change?
Old Mar 5, 2012 | 06:36 AM
97badass's Avatar
It gets noisy when there is no fluid or low, don't ask how I learned that one. The noise taking off in first could be one of a few things, clutch chatter, pilot bearing, throwout bearing, something in the tranny or not enough rpm causing the engine to ping around
Old Mar 5, 2012 | 02:23 PM
robertbartsch's Avatar
does it ever pop out of gear by itself? that could be syncros .... the tranny is pretty stout but if it was ever power shifted ...all bets are off..
change the fluid and hope for the best...
These cars have weak 7" rear ends that were never designed to take any real power. ...eventually it will blow up and give you a big repair expense.
Old Mar 12, 2012 | 05:33 PM
Myersws699's Avatar
It doesn't pop out of gear but the rattling on start with low rpms cuz that fixes it
