Sponsored by: CARiD
Formula Drivetrain Vibration
Old Mar 5, 2012 | 06:29 PM
edobi21's Avatar
Default Formula Drivetrain Vibration
First off, the car is a 96 formula m6.
I've noticed that over 75, in either 5th or 6th gear, there is a pretty bad vibration in the drive train, that continues to get worse as the speed goes up. We've tried a different set of wheels already with newer tires and that didn't solve it. Wondering if anyone else has had a similar problem or any advice? thanks.
Old Mar 5, 2012 | 07:05 PM
JaYZeig's Avatar
possibly bent, or not balanced driveshaft?
any suspension mods...could be that the pinion angle is off..
Old Mar 9, 2012 | 03:06 PM
edobi21's Avatar
No, the suspension is all stock.
Old Mar 10, 2012 | 04:29 PM
Jr.Samples's Avatar
I have the same problem on my 97 Formula, Anything over 70 becomes a little scary like you are driving on the edge of the highway on the part that lets you know you are off the road. Stock suspension.
Old Mar 10, 2012 | 07:31 PM
chrysler kid's Avatar
How about the transmission mount bushing.
Old Mar 11, 2012 | 04:47 PM
Myersws699's Avatar
97 formula ws6 same problem please someone help
Old Mar 11, 2012 | 07:22 PM
fastazzls1's Avatar
look at a post there was on here about the 5th and 6th gear cluster on the mainshaft coming loose and causing problems also put the car in 4th gear and run it through the rpms at the problomatic speed i know 75 in 4th gear see if vibration is still present i had this problem in my t56 bought the new gears and pressed them on easy fix if you are able to rebuild your trans good luck bro
Old Mar 11, 2012 | 07:30 PM
kirbyman03's Avatar
I chased the same vibration in my 98 ss m6 for two years, 2 new drive shafts, wheels,tires, rebuilt my moser and sent my tranny to tick performance for a level 2 build and vib was still there long and short of it two weeks after tranny was in I tried to take out driveshaft and the tailshaft bushing came out with it, tick sent me a new tailshaft with a new bushing and all is great 130+mph. dont spend all the time and money I did and check that bushing.
Old Mar 12, 2012 | 10:11 AM
Jr.Samples's Avatar
I just had my trans rebuilt by TDP I wouldn't think it was that. The trans mount is good. Driveshaft? Maybe. I will try unbolting it and rotate it 180 degrees and see what that does.
By Brett Foote | 2026-06-04 05:00:17
