Sponsored by: CARiD
A/C compressor WTF???
Old Mar 9, 2012 | 09:16 PM
99'CajunFirehawk157's Avatar
Question A/C compressor WTF???
In the process of putting headers on my car, about 98% complete when this happened:
History: My A/c has had a leak since I bought the car 5yrs ago. About a can a year.
A few days ago I took the mounting bolts out of the compressor and moved it forward a few inches to gain more room while doing headers and motor mounts. Left all hoses connected.
When I started this portion of this project a week back on the bottom rear of the compressor by the longest mounting bolt to the rear, I noticed a wet oily coated area and I suspected it is where my leak has been coming from. So today I put it back into place and tightened down all the bolts that hold it on. While tightening the bolt mentioned above on the bottom, all of a sudden I hear a hiss and the sudden rush of refrigeration oil down my arm, something gave away and apparently the system discharged! WTF, is the compressor housing broke, is there a mystery seal in that area that from me tightening the bolt too much gave up the ghost? What could it have been? I know I need a new compressor but would like to know what happened while tightening a bolt cause it to leak out?
Any idea gents
This is not my pic but this is the exact leak in the exact same area...
Old Mar 9, 2012 | 09:47 PM
LS6427's Avatar
Maybe cracked the case somewhere while tightening.....
Old Mar 10, 2012 | 09:25 AM
stevez2885's Avatar
hard to tell without looking at it but i would check the o rings that go in between the lines/compressor
Old Mar 10, 2012 | 11:28 AM
wrencher's Avatar
wrencher
You broke the seal in the compressor housing.
They have to be evenly torqued & to the correct spec.
Otherwise the case can distort & this is a result, all though it blowing out competely is the extreme rarity.
Old Mar 12, 2012 | 03:16 PM
robertbartsch's Avatar
...take the hoses off the compressor, replace the seals, replace the dryer, vacumm the system and only then, fill it back up with freon.
Old Mar 14, 2012 | 07:16 PM
elKameleon's Avatar
Sorry bud but your compressor housing seal is done, I had the same condition as you where the previous owner was adding about a can a year but shortly after I bought the car it wasnt holding at all anymore and when I got under the car I saw exactly as what's pictured in your earlier post and since replaced the compressor and had no more leaks.
