car overheating 210+
any input on what i should do next? fans are working and while cruising temps are 195
i keep seeing ppl on here saying that there temps are 185 in the summer with AC on...id like to get my car like that cause i no if its overheating while its 50 degrees outside..the summer is going to be bad
I would check to see if your water pump is working, it could have seized but you just can't tell because it hasn't been hot enough to over heat outside
