Sponsored by: CARiD
headlight motor
Old Mar 17, 2012 | 01:38 PM
bwilde86's Avatar
Default headlight motor
Changed out the headlight actuator. But now when I turn them off it pops up and when I turn them on it goes down. Did they give me the passenger side instead of drivers?
Old Mar 18, 2012 | 02:09 AM
fastazzls1's Avatar
they need to be resynchronized put them in the up postion when one is up and the other is down manually lift the other light try that first
Old Mar 18, 2012 | 01:16 PM
bwilde86's Avatar
nope stays up when i turn it off...then goes down when i turn the other one on...what else could be wrong?
Old Mar 18, 2012 | 05:20 PM
fastazzls1's Avatar
you got the linkage on there right my brother firebird he had it on the other side of the bump stop and it did this also you could have got the wrong motor on corresponding side i thought they were the same though dnt exactly remeber its been awhile lol
Old Mar 18, 2012 | 08:52 PM
wssix99's Avatar
Save the manuals!
+1 That linkage is probably not on correctly between the stops.
Old Mar 18, 2012 | 09:45 PM
fastazzls1's Avatar
and does the light close all the way and sit flush heres wat i suggest look at the other side and compare were the linkage should sit you will see it when you get the covers off
Old Mar 18, 2012 | 09:49 PM
AmDWs6's Avatar
i took my headlight completely off once and faced such a issue
although keeping them both up with switch on
then shut them off worked.
