Sponsored by: CARiD
Idler spacer
Old Mar 18, 2012 | 04:52 PM
beyonddisturbed's Avatar
Default Idler spacer
So a search hasn't got me very far regarding this issue. I am in need of an ac system idler pulley spacer and a bolt. My torx bolt was drilled out because it was stripped and so I need both of these parts. Does anyone know where I can find them? Thanks
Old Mar 18, 2012 | 05:39 PM
sjsingle1's Avatar
dealer.......the pulley will come with a bolt and washers
Old Mar 18, 2012 | 06:03 PM
and im sure its an arm and a leg. sjsingle1 you got a part number?
Old Mar 18, 2012 | 09:59 PM
finally found it. wow kind of a bitch to find for some reason. not a single thread i could find had it. for those in the future who are looking it is gm part number 12557335 for the idler assembly w/ torx bolt (t-50 i believe) and spacers. snagged it on rock auto for $34 shipped
Old Mar 19, 2012 | 03:51 PM
sjsingle1's Avatar
to bad you needed the bolt and washer......the dayco metal pulley is a better choice
Old Mar 19, 2012 | 10:20 PM
ya idk what gm was thinking with those plastic pulleys. i guess i could swap it in or use it for the tensioner as opposed to keepin the plastic
