need quick AN fitting and hose tutorial
I've never messed with making my own hoses. How do the hose ends work, do i need to buy special tools to get a hose end on?
I'd like to make 2 setups.
One is the oil cooler delete setup where I just have a 6" of hose that does a U between the oil cooler ports on the block.
the other would be a replacement for the stock oil cooler lines which are leaking on me now at the factory crimps, and would also like to put a T block in where I can mount a 1/8 npt sender and use my oil temp gauge.
