Fluid info :)
Trans fluid - its a automatic, so what kind of fluid ? And how many quarts ?
Rear end -how many quarts?
Coolant-how many gallons would I need after a complete flush ?
Thanks again I have searched and came up with nothing for these questions , I really would like to know thanks in advance !!
rear end takes just under 2 qts, you will need to buy 3 because you will either not be able to squeeze it all out of the bottle or get enough out with a gear oil pump.
coolant is 11.8 qts, so either buy 2 gallons antifreeze and 2 gallons distilled water, or 3 gallons of 50/50 premixed.
