Write up for steering rack replacement?
there is no nut, just a shaft coming out of the unit and from what I gather there is a seal around that that I can't get out and I'm not sure if I need to remove the entire rack in order to replace the seal. if so, I'll just replace the whole rack
To the people who have cut the bolt off. How did you do it? I'm in the middle of swapping my rack out and its the only thing stopping it from coming out.
I have a Sawzall and a new 6" heavy duty metal blade. I don't think it's long enough, and I'm not sure there is space to maneuver it back to cut on the bolt. I'm an amateur with a Sawzall as well, truthfully a little scared of it.
Has anyone ever tried bolt cutters?
Thanks in advance. I'm a Noob when it comes to working on these 4th Gens.
A 1/2" bolt was too big for me to replace the one I cut on the passenger side. I had to use a 7/16" x 3". I got the replacement rack from rackdoctor.com.
I used a sawzall and burnt through 2 biablo blades just to get half way through. At that point I took a chisel and a hammer broke the head of the bolt off and pulled it through the bottom. I then took the passenger side bolt to a fastenal and got a bolt the same size to replace the broken drivers side bolt. I put it in upside down.
Moderator
Received 1,852 Likes
I lifted the motor to get that bolt out. it wasn't bad doing it this way. I had to pull the alternator to get the rack out anyway so I had access to the bolt to the MM
