Sponsored by: CARiD
Help with a squeak/rattle (video inside)
Old Mar 23, 2012 | 06:56 PM
Aetos's Avatar
Default Help with a squeak/rattle (video inside)
Anybody know what is causing the sound in this video?
I've changed the tensioner and the sound doesn't change if the A/C is on.
http://www.youtube.com/watch?v=6QIqDmBu0FY
Old Mar 23, 2012 | 07:00 PM
Stippy17's Avatar
Sounds like your AC Compressor is starting to lock up bud.
Old Mar 23, 2012 | 08:56 PM
Aetos's Avatar
A little more information on when this started:
Over the weekend I flushed my power steering and my coolant. At the same time, I also deleted my power steering cooler. The sound started while I was bleeding the air out of the coolant(had already finished the power steering).
I first turned off the car and threw some lubricant into the tensioner pulley, but that didn't do anything.
I later sprayed some lubricant into the tensioner and the sound stopped for a couple of minutes, so I installed a new tensioner, but the sound still happened.
I'm now guessing that while I was spraying lubricant into the tensioner, some lubricant fell onto something else that stopped the noise??
The car seems fine other than the noise. It doesn't overheat, engine sounds fine revving, A/C is still ice cold.
Old Mar 23, 2012 | 09:39 PM
Stippy17's Avatar
You can try spraying some lubricant on one thing at a time until the noise stops, and that should help find the culprit. From the sound I hear on the vid, and your description of it only occuring when the AC is on my guess would be its the AC Compressor. It sounds like it is starting to lock up on you.
Old Mar 23, 2012 | 09:41 PM
Aetos's Avatar
I didn't say it only occurs when the A/C is on. I said the sound doesn't change if I turn on the A/C. I.e. the sound is the same if the A/C is on or off.
Old Mar 23, 2012 | 10:09 PM
Stippy17's Avatar
Regardless. Spray one thing down with lubricant at a time til the noise goes away. You did say that worked before you replaced the idler pulley. It could be a power steering noise. It's possible there isn't enough fluid in the reservoir, or you hurt the pump while flushing the system. Orrrr it could be something else. How does your Serp Belt look? A/C Belt? They can squeek.
