Sponsored by: CARiD
Plug wire question
Old Apr 14, 2012 | 01:09 PM
bigbomber5's Avatar
Default Plug wire question
Im changing spark plugs and wires in my 02 TA. My question is, what is this silver metal jacket piece that is coming off with the wire on the plug side. I'm guessing it is supposed to come off and I insert my new wire inside this then put it back on the plug?
Old Apr 14, 2012 | 01:17 PM
Blu99T/A's Avatar
It is a heat shield.
Yes re-install them on your new plug wires.
Old Apr 14, 2012 | 01:26 PM
bigbomber5's Avatar
Thank you. Just making sure
Old Apr 14, 2012 | 06:00 PM
sjsingle1's Avatar
i did not re-use the metal shields on my MSD or Granatelli wires..........FWIW
Old Apr 14, 2012 | 06:36 PM
bigbomber5's Avatar
Hmm that's interesting. Im using MSD wires as well. It would definitely make popping on the wire a lot easier
BTW, changing plugs and wires makes me hate my car!! I'm on the back 2 on the passenger and called it quits for the day
Old Apr 14, 2012 | 07:27 PM
Blu99T/A's Avatar
I am sorry, I was assuming you were using stock replacement wires. If you are using MSD or any other quality wire, you don't need to use the heat shields.
Old Apr 14, 2012 | 08:08 PM
bigbomber5's Avatar
Cool thanks man.
I read lots of threads before changing the plugs/wires and no where did it mention the metal heat shields come off with your plug. I thought I was yanking **** out of the motor!! lol
I'm going to take them off tomorrow. Should be easy since the driver side is cake
Old Apr 14, 2012 | 08:33 PM
01 CamaroSS SLP's Avatar
Don't use them with MSD
Old Apr 14, 2012 | 09:15 PM
bigbomber5's Avatar
Will do
