Crank but no action....
Okay here we go... I am including two links with short video to see if anyone can help me figure out what and why my car is doing this. I recently rebuilt the engine in this car. The engine is solid and was running fine until today. I installed a new fuel filter took it for a test spin and it died on me and can not get it running again. It acts like a crank no start but both the CMP and CKP are brand new. I am getting proper fuel pressure at the rail. please watch the videos any help is much appreciated.
http://youtu.be/GB36FHjA4Xs
http://youtu.be/N7XfCdjp57M
seems like your having a fuel delivery problem double check the fuel filter installation,or your motor could be flooded, try pushing down on the gas pedal while you crank the engine it should shut down the injectors temporarily then try to start again like normal...best of luck to you.
So after spending a few moments diagnosing further I found out it was not the VATS.... It only took spraying some berrymans B12 in the intake and the car started right up.. So this means the fuel pump is going south... Basically fuel pump is putting out proper pressure but not enough volume.....
Could be the Crank Shaft Position sensor.
