94 TA Headlights Wont Turn On?
My lights go up and down but the headlights won't turn on. Also the high beam light is lit up in my cluster but can't turn it off unless putting the lights down. Checked my fuse in the engine bay and all is fine. What else could it be?
The high beams won't turn on. I pull the lever and nothing happens but the high beam light stays on in my gauge cluster. What relays and fuses are there to check? I've only checked the 15amp fuses in the engine compartment.
Figured out the problem. It was 2 bad headlight bulbs. Everything is working as it should once i replaced the old ones with new. This car was sitting for 3 years and tried using the old stuff before buying new.
