Sponsored by: CARiD
Lights go dim
Old Apr 27, 2012 | 08:55 PM
lil-bit's Avatar
Default Lights go dim
Did a search but not much info. I have a buddy with an 00 ss and a problem just started. The voltage light is fluctuating while hitting bumps N the dash/radio lights go dim. And idea? Altinator? Terminals are tight. Grounds look good... Anything will help. Thank you'll
Old Apr 27, 2012 | 08:59 PM
Maroboy's Avatar
Could be a bad battery?
Old Apr 27, 2012 | 09:01 PM
lil-bit's Avatar
That's what I was thinking too. I would understand that if it just wasn't powering up at all. But hitting the bumps is kina weird
Old Apr 27, 2012 | 09:43 PM
lil-bit's Avatar
Ok so update. It only happens when speed is right at 60 mph.... Any higher or lower it doesn't do anything
