Vapor canister purge solenoid
Check engine light has been on since I got the car it's a 2000 Transam 6 spd with 82,000 this is what comes up when I scan it purge solenoid malfunction I was just wondering if anyone else has come across this
LS1Tech Administrator
Received 1,492 Likes
I have not seen that code, but my purge valve did go bad and cause some idle issues. It was the final thing in a process of elimination which could have caused my issues, and once replaced everything was fine again.
So yes, they do fail.
After trying a new IAC and a second EGR valve (not something you'd have to worry about with an '02) the only thing left that could cause an intermittent vacuum leak that could be cleared with a simple key cycle was the EVAP purge valve. I'm not sure why it never tripped a code, but I did this repair many years ago and the problem never returned.
This condition would usually only occur after long highway drives with sustained speeds above 50mph.
Replaced evap solenoid on the driver side of the intake cured the problem I just didn't want to throw parts at it if it was another problem that would reaccur but thanks for the input guys
